Saltar al contenido principal
Una versión más asequible y puramente portátil de la consola de juegos Nintendo Switch, con controladores Joy-Con integrados y una pantalla un poco más pequeña. Lanzado el 20 de septiembre de 2019.
Preguntas 20 Ver todo
L button not working
L button constantly registers input. I temporarily disabled it from the settings menu and set capture button in it's stead, but this is not ideal. I googled some and it appears I can purchase both L button (although replacing it would require some soldering I imagine) and the whole left circuit board which has all left hand inputs. My question is: which one would be easier to replace and... can you guys suggest me a good guide?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
remove all 8 screws and remove triggers clean with 70% isopropyl on a q-tip to clean and then put back also the design has a problem with it so if the screws are too tight the triggers will well trigger, then it should work no need to solder man it's an input on a hardware not the hardware itself mistily
Update (06/01/2022)
if u need anything else plz don't hesitate to ask we are here to help
Update (06/01/2022)
also how to take it apart Desmontaje de Nintendo Switch Lite
Fue útil esta respuesta?
Puntuación 2
6 comentarios:
Good advice, logical and all. I like logic too, so I did what you said prior to creating this thread and it didn't resolve the issue. I took a clean q-tip, soaked it in a 96% isopropyl alcohol (but not too excessively) and used it to push the button multiple times, so that isopropyl alcohol could make it's way through into button internals and not just outside. I did this, waited about 15 minutes to make sure alcohol inside the L button evaporated completely and then assembled and powered up the console. At first everything seemed fine, until I played a little bit of Hades and the issue came back. So, as I understand, the button is dirty inside and the issue will bother me until I either replace it or find a way to thoroughly clean it somehow. But how? I doubt the isopropyl alcohol can push the dirt out of the button, so it seems like such procedures will have only temporary effect and I'm not okay with that. That's why I decided to ask about button replacement.
- de
Oh, I just realized... It wasn't isopropyl alcohol, it was 96% ethanol. I suppose it can do the job too, but not as effectively.
- de
Regarding screw being overtightened - I don't believe that's the case, since I used the recommended two fingers technique and, to be honest, my fingers are very weak, so I don't think I could have overtightened anything that way.
- de
Furthermore, I just checked the console and the button seems to be working again but I think it's not for long. So, I seek more or less permanent solution instead of temporary one.
- de
I saw left side button boards on Amazon for around 25$ (exactly like the one you can see in step 7 of the teardown you suggested). 25 USD is not that big of a deal for me, so I think a factory assembled option would be better than trying to solder a new button on top of the existing board. Or should I try cleaning the button once again, but with isopropyl alcohol? What do you think? I can buy a bottle. Previously, I just used ethanol alcohol that I had on hand.
- de
Mostrar 1 comentario más
Añadir tu respuesta
Kendrick Howard estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 43
Todo El Tiempo: 6,646
