Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La edición más grande del décimo teléfono Galaxy insignia de Samsung, lanzado en febrero de 2019. Se envía con Android 9.0 (Pie).
Why is the bottom thrid half of my screen flickering white
the thrid bottom half of my phone flickers white and sometimes green and everytime I turn off my phone it won't turn back on unless I press the power button multiple times.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
yo i hav a s10+ too and i dropped and the screen got da same problem
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
@katelynnkatelyn sounds like you are having a broken screen. For now, disassemble the phone, check the display connector to make sure it is properly seated and shows no bend pins, corrosion etc. If that works out okay you will have top replace the display and re-evaluate.
Reemplazo de la pantalla del Samsung Galaxy de Samsung Galaxy S10+
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
The bottom of my phone s10 is flickering constantly like 2/10 of my screen how do I fix the problem??I dropped it but its not cracked
- de
@daevdshula teh glass may not have cracked but sounds like the matrix took a hit. Without seeing it and strictly going by your descriptions, a new display should fix this.
- de
Go to developer mode through settings
Disable HW overlay
And that's it.
Basically it's firmware issue but sometimes this type of error/Flickering is caused by non suitable settings.
Try this bro
Puntuación 1
If u have the eye comfort shield setting on turn it off. This is what fixed it when I had the same problem
Puntuación 1
1 comentario:
Was totally amazed to find that unselecting the Eye Comfort Shield cured my issue. TY for suggesting.
- de
Añadir tu respuesta
kate estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 21
Ultimos 30 días: 118
Todo El Tiempo: 7,404
