Saltar al contenido principal
Lanzada en noviembre de 2020, la MacBook Pro de 13" cuenta con el SoC M1 basado en Arm de Apple con una CPU de 8 núcleos y una GPU de 8 núcleos. (Modelo A2338/EMC 3578 con dos puertos Thunderbolt 3)
Preguntas 91 Ver todo
Right speaker audio comes out through the left speaker
I noticed that my right speakers weren't working so I went to sound in system preference and then balanced my speaker all the way to the right but I was getting audio output from my left speaker which is weird.
Es esta una buena pregunta?
Puntuación 0
4 comentarios
What happens when you bias it the other way?
- de
@danj the audio comes out through the left speaker
- de
@Olasubomi Odekunle - The point was the 'Other' side biasing it that side. So you are saying no matter which way you bias it the sound always comes out the Left only?
- de
@danj yes it always comes out from the left speaker
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Very weird for sure! Did you get your system wet?
Sadly, this sounds like you have a chip failure in the amp logic. I would visit Apple to see if you can get your logic board swapped out as this logic is part of the M1 SoC.
Before you go make a backup as they won't transfer your stuff over.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
No it didn't. I woke up played a YouTube video then realised my right speakers weren't working.
Thank you
- de
@Olasubomi Odekunle - Sorry ;-{ Time to get to Apple to get it fixed, hopefully under warranty. If they say its not covered, press for a warranty exemption as long as you don't have any visible damage or get your system wet they should fix it for free!
Don't forget to accept the answer, thanks!
- de
Añadir tu respuesta
Olasubomi Odekunle estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 69
