Will charge 3 connect to Extreme
Will a JBL Extreme 2 or 3 blue tooth to my Charge 3 ? Is Extreme Connect or Connect +, I believe Charge 3 uses connect?
Es esta una buena pregunta?
As your Fitbit watch has bluetooth capabilities, this should not be an issue. If you follow these steps you should be able to pair the two:
Note Should this not work please power off both devices, and start the procedure again. I hope this helps and if not please return and we will assist further to get you all set!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 174
