Saltar al contenido principal
Casco de RV lanzado el 28 dejunio de 2019
Preguntas 21 Ver todo
Dust on both display panels
When I moved, I somehow managed to get dust inside the headset and onto the display panels. I know it's not on the lens, because moving the IPD shifts the lenses but not the dust specs. Would replacing two (left and right) eye tube assemblies fix this issue?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios
I have a similar issue including scratches and possibly pixels but i cant distinguish if its pixels or dust on the left eye and would also like to know if the tube could remedy this
- de
I used compressed air when I shouldn't have and ran into the same issue, I figured if you can make a strong enough wind current in-between the lens and the display you can pull out any dust, but any solution involving taking the screen off the back of the display cone wont be easy, Ive tried. The only other solution would to be to replace the display cones and maybe replace the rubber seal around the lenses to keep more dust from getting in.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Your problem may not be dust, but my in fact be dead pixels. Regardless, both of these are common problems on the Valve Index
Dust is much less likely being that the eye's are sealed with adhesive, but it is still a possibility. Dead pixels are significantly more common on the index due to their choice in components.
To answer your question: Yes replacing both the left and the right eye tube will fix this issue.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
BBlaze estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 22
Ultimos 30 días: 76
Todo El Tiempo: 672
