The belt is broken on my audio technica turntable
Es esta una buena pregunta?
You should be able to find a replacement belt online, you should also be able to find a manual. Here's a link to a similar (possibly your) model https://manuals.plus/m/310a8717721e78df0...
As you can see the replacement procedure is simple. If you cannot afford or just want to fix the belt itself, a careful drop of cyanoacrylate adhesive (super glue) may give you a temporary fix, for a longer term repair a flexible adhesive reinforced with glas fibers from a bit of fiberglass strapping tape to the outside (non-contact) surface should hold indefinitely.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 103
1 comentario
syz which model turntable?
- de oldturkey03
