Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1418 / Finales de 2012 / 2.7 y 2.9 GHz Procesador Core i5 o 3.1 GHz Core i7
Need to identify blown component on logic board.
After successfully replacing a failed HDD with SSD, reloading from TimeMachine, boot up and login, the last step was to attach new display adhesive and attach the display to the chassis. Starting up again, no display. Opened the system again and found a blown (really blown) component. I must have made some error attaching the display cable. One tech I talked with thought it was a fuse. I need to verify, identify, and determine the value of the fuse/component.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
iMac Logic Board - Something's blown - can I fix it?
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
I'm adding a couple ILHB0805ER251V to my order from Digikey. Hold that thought .........
- de
Exact part. At Digikey, 9 cents. Perfect.
- de
Añadir tu respuesta
Ken H estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 164
