I replaced rear housing and now get white screen of death
I had a working iphone 3gs with a damaged rear casing so I bought a new rear housing fitted with everything aside from motherboard and screen assembly.
I took off screen and motherboard from old unit and put into new rear assembly.
On switching it on, I got white screen of death. Iphone still seems to work - can go into DFU mode and be recognised and restored by itunes.
I tried a few resets and gave up, thinking the rear housing must be faulty so I put the motherboard and screen back into original rear housing. All connectors attached properly and it now gets White screen!
Basically I have taken off screen assembly and motherboard and then put them back and it no longer works.
Any ideas - this must be something simple?
Thanks very much
Mike
Es esta una buena pregunta?
This is easy, well maybe not. You either damaged LCD Display, or Logic Board, or possibly both. Try a new LCD Display, that will answer everything. Before opening and during all repairs of iPhone 3GS make sure the iPhone is OFF or you risk damaging the iPhone.
- de Brad
Thanks Brad - I have ordered another lcd unit to test. I had been very careful and I had made sure that iphone was switched off. I had earthed myself too. I think maybe there was some charge in the new battery in the new housing - maybe that caused a problem.
Cheers again
Mike
- de Mike Paterson
