power and volume dosent work after charging port change
SO i recently dropped my iphone 11 while falling, long story short screen shattered and a little bit of blood did some damage to the phone.started by Replacing the screen, eveything was going good i thought. No phone would restart every 3 mins by its self. Then i found out top volume button dosent work no more and i discoved changing both the volume and charging port will fix my problem NO. Got replacement volume flex cabel and now no volume or power dosent work, i havent put the phone together 100% by tht i mean i havent put the camera back in. Also the replacement charging port isnt OEM so i ordered a OEM one lol so does anyone know why my power or volume isnt working at all?
Es esta una buena pregunta?
To recap you dropped the phone and cracked the screen. After replacing the screen you now have several issues including the phone restarting, volume and power button not functioning.
I would confirm that the connectors for the volume button silent switch ribbon cable and the power button ribbon cable is properly connected to the logic board. Inspect both ribbon cables for any small tears.
Also I don't believe that the charging port should have any effect on the volume button functionality.
I'd focus on resolving the restarting issue first though.
- de Ixxr
Sorry, I initially dropped the phone after tht what happened was the screen broke, volume up broke, and the phone would restart. I fixed the phone screen but NOW the volume or the power button does not work. I’m workin on getting a OEM charging port and that should fix my restarting issues but I have no clue what to do with the volume issue since I bought a new volume button flex cable. Why would the power button not be working now I haven’t touched that!!
- de visva
@ixxrs check out my reply bud!
- de visva
Was the frame or the backglass of the phone damaged when it was dropped? And you have confirmed that the flex cables are not damaged/reseated the connectors for both volume button cable and power button? You have installed a new volume button cable and now have lost all volume and silent switch functionality? If both volume buttons and silent switch does not work its possible the part is either damaged or faulty? I would order replacement power button cable along with another volume/silent switch cable to confirm its not an issue with the part your received. Or another option would be to install your original volume button cable and see if that one still has volume down silent switch functionality. That would isolate the issue further.
- de Ixxr
