Saltar al contenido principal
Released October 2, 2001, identified by model number DVP-FX810
Preguntas 2 Ver todo
Line in won’t work
Line in won’t work with my thing
(Wii av port)
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios:
Logan Lamothe your "thing" being a DVP-FX810? Sounds like you are trying to connect a WII to it. Is that correct? What happens when you try?
- de
No picture appears and it still says line in
- de
Agregar un comentario
1 Respuesta
Logan Lamothe follow the instructions in your manual. If you do not have one, you can download it at places like this
You need to check/set the side switch LINE SELECT IN OUT and see if that changes anything. Of course you also have to make sure that your AUX cable is compatible. Double check the manual for all of this.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Logan Lamothe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 44
