Saltar al contenido principal
Guías de reparación e información de desmontaje para el iPad de novena generación de Apple. Lanzado el 24 de septiembre de 2021. Números de modelo: A2602, A2604, A2603 y A2605.
Preguntas 29 Ver todo
Will the tristar checker work on the ipad 9th generation?
I bought a used ipad 9th generation. Was wondering if anybody knows if anything relating to to the newer model that would make it not a good idea to check it ? I don’t see tristar checkers being sold anymore is why i am asking. Thanks
Es esta una buena pregunta?
Puntuación 0
4 comentarios
why do you need a tristar tester, have you tried an amp meter to check if it takes any power first
- de
I have one already, as a way to further check out the ipad. Amp meter draw still doesn’t mean there could be some other problems with the two chips that the tristar checks out. Just wanting to make sure apple didn’t charge something in the design to render the tri star checker a bad idea for the 9th gen ipad.
- de
No haven’t tried that . Was just wondering if there’s any reason not to use it on an ipad 9 just to verify everything works ok.
- de
Tristar tester should work on any iPad with a lightning port. There isn't an option yet for checking the iPads with a USB C port like the newer pros.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Just saw that this one was listed as unanswered after I commented. Yes, the tristar tester will work. We use the Smartmod Pro version which works on anything with a lightning port.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Perry Green estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 104
