The size of the square nut?
whats the size of the square nut that is used to hold the battery cover on? Can it be order/found from a hardware store?
Es esta una buena pregunta?
Hi!
Not sure about the size, but I doubt if you can buy it separately. I know that if you buy a new shell (for example at AliExpress), you will get a new square nut, which you can transfer to your current back cover.
Example: https://godofgamingshop.com/collections/...
You could also contact them if they have a square nut available.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 241
