The GREEN led on my DS4 wont glow as bright as red and blue ones..
So I've had issues with my DS4 light bar (CHU_ZCT2U), I own 1 of this which the green LED won't glow as bright as red and blue ones,,, any ideas how to fix this? Is there any specific led type for this model?
Here's the comparison with the normal one
Es esta una buena pregunta?
Puntuación
0
Hi! Do you have a photo regarding the issue? And so that we can compare? And yes, the micro usb connector also has a LED on it. The are many different LED boards, so the best thing is to open it up to see which one you got, if you want it replaced.
- de koppie007
@dan0 Sorry for the late response. I've updated the question with comparison pictures attached.
- de Rizka Faisal
@Rizka Faisal No problem at all! Hmm, is it completely charged? And is the battery still ok? I know, that you can change the brightness at the PS4 it self, is this set to "Bright"? If both yes, I would try to replace the LED board to see if that makes any difference. It's easy to replace and not that expensive (make sure that you have the correct LED board, there are many of them).
- de koppie007
@dan0 I've tested the LED spectrum using DS4Windows before posting here, and sadly it's the latter case. Well, okay, I think I'll need to flex my finger joint to open this thing and see what's wrong inside! Thanks for the advice!
- de Rizka Faisal
@Rizka Faisal Your welcome :)! Yes, I'm afraid you should replace the board. Fortunately it's not expensive and easy to fix.
- de koppie007
