Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
A1418 | EMC 2889 | Finales de 2015 | Intel Core i5 de doble núcleo a 1,6 GHz o Intel Core i5 de cuatro núcleos a 2,8 GHz. Lanzado el 13 de octubre de 2015.
What do I need to purchase if I want to replace the HDD with an SSD?
Looking to replace the HDD in my iMac with an SSD. I have an SSD on hand but want to know do I need to purchase anything such as a temp sensor? I know older models needed some after market temp sensor otherwise the fan would run at 100% all the time. Is this still the same with this model or am I able to replace it without purchasing a sensor? What else would be recommended to make this process easier? I know I will need the little cutter that ifixit sells and some new adheasive. Any recommendations are also welcome.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Here’s the guide Reemplazo del disco duro de iMac Intel 21.5" EMC 2889
You don’t need any thermal sensor for your system, But I strongly commend you get the tools and sundry items listed out here iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit And make sure you follow the guide to the letter using the special cutter wheel as many people have damaged their display using the wrong tools.
Imagen de Upgrade the storage and improve boot time and read/write speed in your iMac Intel 21.5" Late 2012-2019 with this SSD upgrade kit.
Producto
$82.99
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Dudefoxlive estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 166
