Blinking red light on left bottom of laptop
What does the blinking red light on the bottom left of the laptop indicate? Normally it is just a blue solid light.
Thanks !
Es esta una buena pregunta?
Thanks !
Hi Danny,
You don’t mention whether it is the Power or the Battery light and do you perhaps mean ”blinking amber light”? Does it happen when the computer is on or off?
The power indicator (looks like a light bulb) which indicates the computer power status:
Battery indicator (looks like a battery with a lightening bolt through it) which indicates the computer battery status:
Fue útil esta respuesta?
Hello , I have a problem too . My Acer aspire es 14 having red light when plugged in the charger and sadly the battery icon stop charging . Wala naman po nakalagay na charging or not charging . I changed the adoptor too and outlet pero Ganon paden . New po kase ang battery ko and 14 v lng sya with 2600 mAh po . How to fix ? Then one time problem then po is mabagal na sya mag function
Hi @norvy ternal ,
We will need the exact model number of the Acer Aspire ES14.
You say "red" but do you mean amber?
The battery should be
Capacity: 5000mAh/56Wh
Battery Voltage: 11.1V
As your is a different model you should post it as a new Question.
Hello my Acer laptop is flashing blue light when it's off but wouldn't turn on
Hi @reba97586
Which model of Acer laptop do you have?
It's happening to me to it keeps blinking red what do I do?
Ultimas 24 horas: 5
Ultimos 7 días: 57
Ultimos 30 días: 291
Todo El Tiempo: 8,304
1 comentario
I experience the same problem with my acer laptop. The laptop is on and the battery is still at 85% (last i checked when it still displays the battery icon) but the battery light keeps flashing an amber colored light. My laptop Acer Aspire E 14 E5-476G-32HR (not sure if that is actually the model)
- de Crimson Grey
