Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La sexta generación del Subaru Legacy se presentó en el Salón del Automóvil de Chicago de 2014 y entró en producción para el año modelo 2015.
check engine light on code p700.
i got this check engine light everytime it rains . i scan the code and it show p700 . ( transmission failure ) however the car run okay no problem and after 2 days of doing running the check engine light will turn off.
Es esta una buena pregunta?
Puntuación 1
1 comentario
See if the diagram here helps. It's from the Outback Owners site.
https://www.suoutback.com/transmission_h...
- de
Agregar un comentario
1 Respuesta
Solución Elegida
It could be a number of issues but when you said it mainly happens when it rains then i would put money on it being a bad connection in the wiring harness to the transmission. Maybe water causing a short circuit & then once it’s dried out the transmission control unit thinks the fault has cleared.
I would follow the wiring harness from the left side of the dash, through to the gearbox. Checking for any breaks in insulation & also the security of any connector blocks outside of the interior of the vehicle. I know the Subaru Forester has 2 BIG connector blocks on the top of the gearbox around the bell housing area. It maybe the problem lies in those. Google your transmission wiring harness & see what the photos show you.
Good luck
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
EDWIN CHAN MENCIAS estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 16
Todo El Tiempo: 627
