Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
MF6530: Persistent paper jam. Took video in the tray. No error code.
Problem
The display says "Paper Jam / Open Left Cover" without any code. I don't think the jam is real.
Why I don't think there is a real jam
I put a camera inside the paper tray and upload the video to youtube
In the video, I see the following things.
  1. At 0:03, the cassette pickup roller (CPR) would push the top paper forward
  2. At 0:04, the CPR would push that top paper once more. After that, the top paper completely goes in.
  3. At 0:06, the CPR would push the 2nd paper.
  4. Then the printer says it gets a paper jam.
The top of the 2nd piece of paper is right at the end of the registration roller. The paper doesn't go a bit beyond the registration roller. After I open the left cover, I can't just pull that single piece of paper out. I have to manually roll the roller to get the 2nd paper out.
Retry Pickup?
On page 111, the service manual talks about a "Retry Pickup":
  • If the registration sensor(SR11) does not detect paper within a specific period of time after the cassette pickup roller has started to rotate, the machine will start to rotate the cassette pickup roller once again to execute a retry pickup operation
  • If the registration sensor (SR11) still does not detect paper within a specific period of time after executing a retry pickup 3 times, the machine will identify the condition as a jam and will indicate a jam message on the LCD of its control panel
At first, I thought maybe SR11 was faulty and couldn't detect the paper. That would make the machine do that "retry pickup".
But I am not sure because I *can't* even see an error code for the jam.
My attempt to get the error code for the jam
Does a jam always have an error code? If that is the case, how to see that code?
I have tried:
  1. Go into maintenance mode ([additional function], [2], [8], [additional function])
  2. Clear history of error
  3. Copy something and let the paper jam.
  4. Print the history of errors
But that history is blank.
Sensor Tests
I also did several sensor tests using the normal sensor mode (not the latch mode).
Testing the Sensor for Papers in Tray
Test of the cassette paper sensor (SR9):
  • When I remove all papers in the paper tray, the display says "CAS 0".
  • After I put papers back into the tray, the display says "CAS 1".
When the tray has papers, CAS = 1. When the tray has no paper, CAS = 0.
What I see: 0/tray has no paper, 1/tray has paper.
But page 224 (F14-14) of the manual says the exact opposite: "CAS: Cassette paper sensor (SR9): 0/Document presence, 1/Document absent".
Testing the Registration Sensor
  • When I did a sensor test after the paper jam, I saw "REG 1".
  • After I removed the paper, I saw "REG 0".
What I see: 0/no paper, 1/has paper.
The manual says the exact opposite: "REG: Registration sensor (SR11): 0/Document presence, 1/Document absent”
Testing the Delivery Sensor
  • I ask the printer to make a copy. Before the printer completes the print, I open the left cover.
  • Before I remove the half-printed document, the sensor test says “DEL 1 0”.
  • After I remove the half-printed document, the sensor test says: “DEL 0 0”
What I see: 0 0/no paper, 1 0/has paper.
The manual says the same thing: "Delivery sensor (SR5): 1/Document presence, 0/Document absence.”
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
hii my printer in not working properly
- de
Agregar un comentario
1 Respuesta
Turn the printer in an unusual way. Like on its side or upside down. If you can shake it a little. There may be something small lodged somewhere inside. There may be nothing lodged inside but maybe residue build up is causing the problem. Use sparingly alcohol whipes.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Could also be a broken piece not making contact with a sensor, we had that on one of our RICOH machines a while back
- de
Añadir tu respuesta
mf6530 test estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 414
