Tried everything to remove tiny screw in ear thermometer
Hi, I am trying to remove the screw on an ear thermometer, so I can change the battery. I have tried - what I think - is everything. (May I send 2 pictures?) Nothing is working: household oil, WD-40, white vinegar, rubber band. I have used the preceding with the correct size of screwdriver. I can give up, and purchase another, but I want to be assured that I am not missing a solution. Is there something else I can do?
Update (02/26/2022)
Here are some pictures to refer back to earlier helpful answers. (Am still working on removal…)
Es esta una buena pregunta?
7 comentarios
My apologies for not including the following in the original description. I wanted to add that I tried other tools in my mini-screwdriver set (a mini flathead and one with a tip like a large straight pin), to separate the screw from the screw well. This didn't work either. I welcome your good advice!
- de honoria glossop
If you can add pictures of the screw I can tell you what kind of screw driver is needed.
- de Lee Cooper
a make and model might be good too.
- de bill
Thank you so much for your answers. I apologize for this delay. There is still ice here, and there was a mishap...
Here is a picture of the make and model. Also, I think that I am actually using the correct screwdriver. I am the lucky recipient of 3 sets of these mini-drivers, and I think I can definitely feel it engaging when I use the right one. It is just that I cannot make it rotate. Here are a couple of pictures. (I feel so dumb; I'm now not sure where to attach these pics...)
I have to humbly ask how to respond or comment, with an image...
Mostrar 2 comentarios más
