Saltar al contenido principal
El primer Altima se produjo en junio de 1992, como modelo de 1993. Todos los Altimas se construyeron en Smyrna, Tennessee, hasta junio de 2004, cuando la planta de Nissan en Canton, Mississippi, también comenzó a producir el modelo para satisfacer la alta demanda.
Preguntas 7 Ver todo
has problems starting most of the time
I have a 94 Nissan Altima 4 cylinder that has problems starting most of the time. If I pull a plug out I am getting spark and it allows the car to start, but put it back in then it doesn't start... Help please...
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Dave Scott could be many of things. If it has spark it most likely has spark when it is back in the cylinder head. So that would leave either fuel or air as a possibility. Check your fuel filter and pump to make sure that you have the right fuel pressure on that. The other thing you need to check for is that the spark happens a the right time. So you need to check the crank position as well as the cam position sensors. I would strongly suggest that when it runs, take it where they can scan the vehicle 's OBD to see if and what codes you get. Otherwise you might be spending a lot of money for parts that are not needed. Depending on where you are, places like Autozone do the scanning for free. Let us know what the exact engine is and what you have checked so that we may provide a more in depth answer
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
I have replaced the fuel pump, battery, and fuel injectors it is getting gas, also should note that after replacing each the car started like the problem was fixed I shut it off came out next morning back to not starting, has me very confused. Was going to take it to shop down the road but won't start now..
- de
Sorry, forgot to also mention the spark plugs and wires were also changed recently.
- de
What about the cap and rotor?
- de
Añadir tu respuesta
Dave Scott estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 219
