Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Segunda generación de iPhone. Modelo A1241 / 8 o 16 GB de capacidad / plástico negro o blanco de nuevo. La reparación es más sencilla que el primer iPhone. Requiere destornilladores, curvas y herramientas de succión.
How To Program iPhone 3G LCD/ LCD Datasheet
This question also appears on the "Discuss" board.
I like working with microcontrollers such as those in the Arduino platform. Now that I've replaced the entire display assembly of an iPhone 3G with a IF137-008-1, I'm left with a perfectly good LCD unit that the customer won't want. Is there a datasheet for the LCD and perhaps even a development type PCB that I can plug it into and play with?
For example can I set this up so an Arduino Mega can send a jpg photo to the LCD with some nice caption text?
Thanks
Bob
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Solución Elegida
from some teardown reports I have read, I heard that there are maybe 3 likely manufacturers of the LCD module:
- Toshiba Mobile Display
- Sharp
- Samsung
However I'm not sure if it's easy to find the datasheets for the specific panel, but you may be able to do some digging knowing the makers. I don't know if the manufacturer's part number appears on the panel.
on the other hand, I also read that the iPhone 3G uses a National Semiconductor chip to interface to the LCD display, the LM2512AA Mobile Pixel Link display interface
http://www.national.com/pf/LM/LM2512A.ht...
perhaps you can get a clue from it's data sheet and go from there.
have fun and good luck
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
cochranb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 12,943
