How do I replace my microSD card slot?
The thing just isn’t retaining my memory card, and I think it’s done for. How do I replace/repair it?
Es esta una buena pregunta?
I think you will just have to use this: Galaxy Tab 3 8.0 Motherboard
It is out of stock right now. This guide should help with that: https://www.ifixit.com/News/56864/findin...
Fue útil esta respuesta?
cheers m8, i have another samsung tab 3 that i could cannibalise
i just practiced disassembling it
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 224
6 comentarios
Do you have a hot air station?
- de Andrew S
nope
i guess i'll just replace the motherboard
- de notnice -96
i'll need to back it all up
- de notnice -96
@andrewsawesome what if i did?
- de notnice -96
@notnice -96 If you were able to find a replacement microSD card slot, you could use a hot air gun and flux to heat the solder around the microSD card slot, then remove it with tweezers. You would then tin the pads(put solder on rhe pads with a soldering iron) and heat up the board for the new microSD card until it goes into place.
- de Andrew S
Mostrar 1 comentario más
