Saltar al contenido principal
Una versión más asequible y puramente portátil de la consola de juegos Nintendo Switch, con controladores Joy-Con integrados y una pantalla un poco más pequeña. Lanzado el 20 de septiembre de 2019.
How To Remove stripped screws from back shell
while trying to open up the lite I stripped the screws by putting to much pressure on screw driver carving a shape into it I was able to get one out (it wasn’t stripped) I got the screws to replace them but I can’t get the stripped screws out it’s in the top left bottom left and bottom right
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
I have a similar issue, I am going to try and put a tiny dot of glue on the tip of the driver, hold it against the screw till it dries and hopefully i can turn the screw afterwards...wish me luck!!
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
YouTube is filled with suggestions on removing stripped screws. However, look carefully because some of the methods are fine for removing a screw with a stripped head from wood, but would destroy something plastic, like your Switch. Don’t use a propane torch to heat the screw and don’t use any sort of impact tool.
It’s an art form and some methods won’t work at some times.
Rubber band - I haven’t found this works
Latex glove- I haven’t found this works
Mini screw extractor
Left hand drill bit
Metal drill bit
And others
Here are some vids that are focused on removing stripped screws from small electronic devices.
IFixIt carries this, which is shown in the last vid.
Precision Screw Extractor Set
https://www.youtube.com/watch?v=xaQ9eX-b...
https://www.youtube.com/watch?v=TEYgVsPc...
https://www.youtube.com/watch?v=s06UWk_N...
https://www.youtube.com/watch?v=wpgc9rAA...
https://www.youtube.com/watch?v=kfcU2f7S...
Imagen de Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm.
Producto
$24.99
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
mat estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 90
Ultimos 30 días: 397
Todo El Tiempo: 34,733
