From TheBookYard
iMac 27" LED Backlight Board V1 (4-Pin)
This is the first revision of the backlight board. To differentiate between the two versions, you will need to confirm how many pins the V-Sync socket has on your current board, as the backlight board needs to match your LCD version. (unfortunately, apple use the same part number for both, so they cannot be differentiated in any other way)
This version of the backlight board has a 4-pin V-Sync socket.
The EEE codes that match this version are as follows:
LCD EEE: DJ4K
Backlight Board EEE: HQH, HQG
(to identify the EEE code, please look at the serial number of the part itself, not of the machines serial number. it will be as follows XXXXXXXXEEEX)
iMac 27" LED Backlight Board V2 (8-Pin)
This is the second revision of the backlight board. To differentiate between the two versions, you will need to confirm how many pins the V-Sync socket has on your current board, as the backlight board needs to match your LCD version. (unfortunately, apple use the same part number for both, so they cannot be differentiated in any other way)
This version of the backlight board has a 8-pin V-Sync socket.
LCD EEE: DL1M
Backlight Board EEE: DDHQ, DJ5T
(to identify the EEE code, please look at the serial number of the part itself, not of the machines serial number. it will be as follows XXXXXXXXXXXXEEEEX)
