Saltar al contenido principal
El iRobot Roomba 870 es un aspirador robótico automatizado que forma parte del iRobot inc. serie 800 Roombas.
Preguntas 8 Ver todo
Why is the display of my Roomba 871 continuously showing RST?
We came back from holidays and discovered the roomba 871 had RST in the display and would not respond to charging, Clean button or any other button. I have removed and put back the battery and still get the same.
I have read jt in another forum it may be that the Clean button is shorted - hence why it is always as if it had been reset. Can anyone confirm ? And if that is the case, how can I fix it?
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Pab Car it is possible that it is your Clean button but start with a new battery first. It can cause the same issue. If nothing else it will provide you with a known-well starting point should further troubleshooting become necessary.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Pab Car estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 191
