Saltar al contenido principal
Procesador Core 2 Duo de 2, 2.26, 2.53 o 2.66 GHz
Partially broken power connection cable (that goes to the logic board)
Hello,
as I was cleaning the dust off my old late 2009 mac mini I accidentally broke the lower part of the casing shell on the cable that goes from the power button down to the logic board. I managed to pretty firmly attach the two wires correctly to the board and the machine works fine.
My worry is;
1) If the dust buildup could cause a short with that little opening without the shell (see the two metal cable ends of the two wires without the casing shell)
2) Could I easily cover it with something like electrical tape, although the common understanding is that electrical tapes are not ideal for this task (heat & the gooey adhesive they leave behind).
What would be the ideal solution if you think I should cover up the remaining part of the partially broken casing shell on the cable?
Thanks in advance!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The best solution is to replace the cable assembly (part of bottom case) or at least splice in a replacement connector.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thanks, I found an older mini, will try to use its power button.
- de
Añadir tu respuesta
Berk estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 248
