Saltar al contenido principal
Plantronics Voyager Legend es un auricular inalámbrico con Bluetooth, compatible con la mayoría de los teléfonos móviles disponibles en el mercado. Lanzado originalmente en septiembre de 2013, este dispositivo sigue siendo popular entre una amplia variedad de usuarios.
Do battery replacement instructions also work for Voyager 5200?
The Plantronics Voyager5200 looks almost identical but is in fact different (Rtings has side-by-side pictures). Do the battery replacement instructions for the Legend also work for the 5200? Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
basically yes they are almost identical. Just be sure you get the right battery with the right leads.
Fue útil esta respuesta?
Puntuación 0
5 comentarios:
Did you actually perform a battery replacement on the headset? I am sure that they are identical from the inside, but the fastening of the case looks quite different, if you look at the pictures.
- de
@jastram I did it on the new one. They are the same type of pressure snap clips so be gentle when you separate.
- de
@jastram
https://www.youtube.com/watch?v=oXuHwYJv... (Legend)
https://www.youtube.com/watch?v=odVpATQO... (UC)
Hope this helps a bit more than me just saying it's very similar!
- de
Those videos are useful, thanks. In fact, they show that disassembly is easier than with the Legend.
- de
@jastram not a problem. if this answered your question please chose an answer but if you have issue you can still come back and ask
- de
Añadir tu respuesta
Michael estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 658
