Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Panasonic Lumix DMC-FZ1000 es una cámara digital de lente única con pantalla giratoria, lanzada el 27 de julio de 2014 por Panasonic.
The micro HDMI port on my Lumix FZ1000 has stopped working.
I was using an adaptor to connect the micro HDMI port of my FZ1000 to a full size HDMI cable and all worked fine. The weight of the full size cable eventually bent the adaptor, it broke, and appears to have damaged the port on the camera as several other adaptors, specified as working with a FZ1000, will not work. I have reset the camera to factory defaults but there still is no video output on the micro HDMI port. Can the micro HDMI port be replaced?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Most cell phone repair business can probably replace the broken ports. It may take a bit for the parts to come in but unless you have done electric soldering in the past than for a camera being so compact I recommend a repair shop.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Brendan Mullan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 702
