Saltar al contenido principal
Guías de reparación y soporte para cajas registradoras.
Preguntas 53 Ver todo
G800 SD electronic cash register
Hi how are u hope ur fine, ,may kind assist me with my G-800 SD electronic cash register,, the upper black button that use 3 keys is missing ,the one that is used to control the use of the cash machine I don't know how i missed it ,and the machine is still brand new never 4been used before, may you kindly help me with replacing that button and please assist me with giving me giving me the user manual again I misplaced it. thanks you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
You can get the manual for this cash register at https://data2.manualslib.com/pdf4/88/872...
- de
Agregar un comentario
1 Respuesta
https://www.manualslib.com/manual/872656...
here is a search for repair places. you can call and order what you need but there really isn’t much online as these are basically a closed parts system like ATMs are.
https://www.google.com/search?q=nts+cash...
however if you are referring to the keys that unlock it for use than you can also get them from these places but you will need the serial and model numbers off the register. usually these are a stick on the underside of the unit.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Eva Mogale estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 187
