Rear camera lense iPhone 12 Pro Max
The telephoto camera (bottom left) glass that covers the actual lense is cracked exposing the lense of the camera. What component do I need to change to repair it?
Es esta una buena pregunta?
To replace cracked lens glass, use iFixit's replacement rear camera lenses and bezels in addition to replacement adhesive.
Fue útil esta respuesta?
Which bezel goes with which iPhone lens? The product comes with three different size bezels.
You can buy replacement glass on eBay etc, usually come as a set of three. Make sure they come with the adhesive rings. You have two choices.
Remove the damaged glass from the outside using a sharp blade to pick the glass out and risk damaging the camera lens itself or open the phone, remove the camera module and push the glass out from inside.
A shop would charge maybe 25 pounds to do it.
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 617
