Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1418 / finales de 2012 / procesador Core i5 de 2.7 y 2.9 GHz o Core i7 de 3.1 GHz
Does i7 3770K work for iMac 21.5” late 2012?
Does i7 3770K work for iMac 21.5-inch late 2012 (iMac 13,1 model:A1418(EMC2544)).
Because someone told me K version is not supported and as a result I need i7 3770s for upgrade?
Is it true?
Thank you.
Es esta una buena pregunta?
Puntuación 0
1 comentario
not sure for the 21” (probably does) but the 27” the 3770k works with Open core legacy patcher and an SSD on mac os 15.5
- de
Agregar un comentario
1 Respuesta
Solución Elegida
First lets work off of the spec sheets:
The chip you are asking about: Core i7 3770K
Your systems series: Late 2012/Early 2013 - 21.5” iMac (iMac13,1) The best you could use is I7-3770S
Here’s that chips spec sheet: Core i7 3770S
So what is different?? The TDP 77 W vs 65 W
So bottomline you need the Core i7 3770S chip! As your systems cooling and power is not designed to support the hotter running chip.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Samsamsam Wong estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 965
