Saltar al contenido principal
Lanzado el 20 de septiembre, el teléfono inteligente 2019 más grande y caro de Apple presenta una pantalla OLED de 6.5", un sistema de cámara de triple lente y una vida útil de la batería mejorada. Sucesor del iPhone XS Max.
Will the LCD Screen Replacement Cause Board Damage?
Hello everyone, new here.
So, i have a completely destroyed iPhone 11 Pro Max that i would really like to fix up to avoid it becoming just more e-waste. Question is, i’ve done a bit of research on LCD displays retrofitted onto OLED iPhones and from what i see they usually cause board damage because of more power draw, but i wanted to find out if this magically happens to not be the case with the iFixit display.
Thanks a bunch for all the help!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
The issue is on a OLED the backlight pulls more power to give bright displays. however not all backlight leds are created equally so this is something you may want to call ifixit about.
Fue útil esta respuesta?
Puntuación 0
the power ic went off
Puntuación 0
2 comentarios:
Bummer dude.
- de
@adomchrisofori, is there a question in there? With just your statement we have no way of knowing what you're looking for by coming here. Are you saying your power IC died? How do you know that? What relationship does your question have with a post regarding using an LCD display on a phone originally designed for an OLED display?
- de
Añadir tu respuesta
Tyler estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 57
Todo El Tiempo: 427
