Why is no fuel getting in the cylinder an not starting
Is there any way any one has a manual for it
Es esta una buena pregunta?
change the gas line and remove the carburetor. use carb cleaner and remove everything to pieces and blow the cleaner in every hole. the float bowl injector is the screw that holds the gas reservoir of the carb to the engine. this is usually the culprit and needs to be cleaned.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 788
3 comentarios
Hello snsjss
- de Ethan
@walker34 your blower a Homelite backpack blower (bp250)? If not we need more info about what engine it has etc.
- de oldturkey03
Plugged gas line, fuel filter, fuel valve or carburetor gummed up.
- de bill
