Saltar al contenido principal
Adaptador de corriente alterna magnético de segunda generación para productos MacBook, lanzado por primera vez en 2012. No es compatible con sistemas de generaciones anteriores Disponible en versiones de 45W, 60W y 85W.
Preguntas 23 Ver todo
Is there a known Mag-Safe II to Mag-Safe III adapter available yet
I’m working on a new 14” M1 MacBook Pro and was so glad to see the return of the Mag-Safe adapter but it is an updated version of the Mag-Safe II only a little longer and slimmer. I am looking for an an adapter to use on the Mag-Safe II to convert it to a Mag-Safe III but have been unable to locate one yet. Are the any alternatives?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Boy @mayer you couldn’t wait ;-}
I’m not sure if it would work either way.
Apples MagSafe & MagSafe-2 used a one wire dialog that was unique to them. While the MagSafe-3 is similar in that its five contacts I’m not sure what Apple has done here.
If you review the iFixit teardown 2021 MacBook Pro Teardown: A Glimpse at a Better Timeline The green three chips on the left are top to bottom MagSafe, USB-C port 1 & USB-C port 2 and all three are using the same Apple APL1098/343S00515 Power Management chip so I’m surmising the dialog is based on the USB-C power spec not Apples one wire comm connection.
Sorry Mayer ;-{ If someone is able to do it, its likely going to take a bit of time before they get released.
So how is it? And which one did you get?
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
@danj It's one day old, M1 Pro that I'm transferring user data over from her old Mac. Apple wants $49 just for a cable: https://www.apple.com/shop/product/MLYV3...
- de
@mayer - You mean its not even yours ;-{
I'm seriously thinking of going with the 16" M1 Max 32GB 1TB drive. The notch is the only thing holding me back.
The cable is the weak link in the older chargers at least Apple smarted up giving us the ability to replace it without the charger and yes, its to expensive!
- de
@danj The cable appears to be much better quality, made of woven material rather than the old plastic.
- de
@mayer - Yes! But will it last longer, I hope so for such an expensive cable.
- de
Respuesta Más Útil
I guess it’s not going to be easy. Looking at the teardown of the MagSafe3 cable, it looks like a Type-C PD cable in disguise, so none of the old protocols work.
MagSafe to Magsafe2 adapter is basically just a passthrough, not possible with MagSafe2 to MagSafe3.
Puntuación 2
Añadir tu respuesta
mayer estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 32
Ultimos 30 días: 182
Todo El Tiempo: 3,041
