Saltar al contenido principal
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
Preguntas 20 Ver todo
Why does my device overheat so often?
Good afternoon, I have a big problem. I have Asus Eee PC 1005HA. And it started to overheat very often. I often have to work at the computer and write a lot of articles, but lately my device began to overheat and shut down very often.
How can I solve this problem? Should I upgrade to a more powerful device, or is there anything else I can do about it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Have you had the laptop for a long time? If so, if you have never taken it apart the entire time you have had it then it might be dirty inside and probably needs new thermal compound on the CPU. That is most likely the problem.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
brian johnson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 144
