Saltar al contenido principal
El PowerMac G5 es un ordenador de escritorio producida por primera vez en 2003 por Apple Corporation. Esta guía revisará el proceso de reparación de un número de modelo Apple PowerMac G5 A1047 EMC 2061 de 2004.
Preguntas 193 Ver todo
fan noise as soon as I turned on the G5
Hi,
My computer is working fine except sometimes I cannot make it
go to sleep. I hear a noise that seems to come from the fan, I assume is the fan because the computer works perfectly fine.
The sound is like a motor been tired a constant sound like
and rrrrrrr..rrrrrrr.rrrrr.
Any suggestions where the sounds it can came from?
Thanks,
Mia
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
3 comentarios
Do you have it closed up or have you removed the plastic cover? Is it off? Has it ever been taken apart? The sound is coming from a fan, we just need to determine why. How are you trying to put ti to sleep?
- de
I clean my computer in a regular basis, the plastic cover is in. I don't have apple care
anymore. I think shouldn't be a big of a deal to change the fan if I decide to.
When I try to make it sleep is from the apple menu bar
Apple /go to sleep, for seconds seems that is doing it. but a little click like
a switch. make it turned it on again.
Thanks for your reply.
Mia
- de
Let's check some settings.. Go to System Preferences - Energy Saver and check the bar next go to Desktop & Screen Saver and check the Start Screen saver bar.
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
I'm not too farmilier with this mac, but it looks as if it's overheating (Or at least thinks it is). Have you removed the processer heatsink cover, and checked for leakage from the Liquid Cooling Unit? (This was only there in later dual, and quad models) try remoiving the cpu's, and cleaning the dust from the attached heatsinks.
Fue útil esta respuesta?
Puntuación 3
5 comentarios:
DO NOT REMOVE THE CPU's unless you have the fan recalibration software only available to Authorized Service Providers.
- de
There's software needed to re-calibrate the fans? Apple can't seem to meke anything easy on these machines, can it?
- de
I've been trying to get this software for 3 years.
- de
Me too! If anybody has access too this software drop me a line: info (at) re-mac.de
- de
The fan syncing software is on the original system installation disk. Start up holding down the "D" key.
- de
Hi
This is Ejaz. The Mac will not go to sleep and make those sound,if you are using 3RD party memory. Because on some memory chip,sleep controls only works only PC platform not on MAC. Mind you not all memory are totally compatible with MAC.
Thanks
EJ
Puntuación 1
You reset PRAM and NVRAM for setup default the sensors
turn off mac g5
turn ON mac g5
before you see gray screen down
holddown COMAND + OPTION + P + R
mac g5 is startup
and you wait ear 2 sounds of startup
now holdoff key COMAND + OPTION +P +R
the g5 setup now on default
when start up
go system preference
go energy saver
go nergysaver/option
go velocity of procesor and setup slow
with this your g5 work silence and fine
Puntuación 0
Añadir tu respuesta
mia estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 8,704
