yesenia Guzman for now you want to stop continuing to try to charge, sync, or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your phone. Use these guides iPhone XS Max to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors, etc. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and repair. It does not matter if it was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage. It is possible that you have a bad LCD and replacing the display assembly may fix it. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Google Translation
yesenia Guzman por ahora quieres dejar de seguir intentando cargar, sincronizar o usar tu teléfono. Potencialmente, esto puede empeorar una mala situación. Esto puede dañar aún más su teléfono. El primer paso que daría es desmontar tu teléfono. Utilice estas guías de reparación de iPhone XS Max para ayudarlo a desmontar su teléfono. Observe con detenimiento y de cerca todos los componentes y conectores. Evalúe verdaderamente el daño. Busque corrosión importante, evalúe las clavijas de los conectores, etc. Observe todos los conectores y los extremos de los cables. Tendrá que quitar todos los escudos EMI. Si no quita los protectores, no está limpiando la placa. Una vez que haya limpiado la contaminación grave, use 90% + alcohol isopropílico y limpie sus piezas un poco más. Para una limpieza adecuada, use esta guía. Fue escrito para un iPhone 3G de Apple, pero también es pertinente para su teléfono. No puedo enfatizar la importancia de una buena limpieza, así que hazlo una y otra vez mientras reemplazas el alcohol después de cada limpieza. No use aire comprimido para la limpieza, ya que puede conducir líquido y partículas de corrosión a áreas que causarán problemas más adelante. No use agua potable, si necesita usar agua, use agua esterilizada. Además, no es necesario que lo dejes secar durante un día. El alcohol isopropílico en la concentración más alta se evaporará rápidamente y disipará el agua. La importancia aquí es la limpieza. Por supuesto, lo mejor sería limpiarlo por un profesional. No olvide reemplazar la batería. Esto es imprescindible y no una opción. Fallará si no lo atiende ahora. Después de eso, vuelva a armar su teléfono y reevalúe. Mientras no haya limpiado su tablero y reemplazado la batería, todo es solo una suposición. Tenga en cuenta que los daños causados por el agua son los más difíciles de solucionar y reparar. No importa si estuvo expuesto durante 2 segundos o 2 horas, lo que importa es dónde el agua (partículas) hizo el daño. Es posible que tenga una pantalla LCD defectuosa y reemplazar el ensamblaje de la pantalla puede solucionarlo. Incluso con todo esto, el daño causado por el agua solo tiene una pequeña posibilidad de repararse por completo, pero al menos puedes intentarlo.
