Very high leak rate on report screen
I get very high leak rates 40 to 70 L/min indicated with no mask seal alert and no warnings. Mask,tank,and tube all check good with no leaks
Es esta una buena pregunta?
i have same problem i fix it by replacing the mask and program the cpap with the new mask .. it works.
Fue útil esta respuesta?
I have the same issue. I’m replacing the first internal gasket before I try the harder to replace air pump gasket. https://www.directhomemedical.com/resmed...
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 520
