Saltar al contenido principal
El Mercedes-Benz W126 es una serie de automóviles S-Class fabricados por Mercedes-Benz entre 1979 y 1992. Estrenada en septiembre de 1979 como el sucesor de la línea W116, el W126 fue la segunda generación en llevar oficialmente esa prestigiosa designación, una abreviatura para el alemán Sonderklasse o "clase especial".
Preguntas 9 Ver todo
gas fumes but no apparent leak
gas fumes are apparent but no apparent leak
Update (09/02/2021)
Hi Brandon, Thanks for responding. I’ve had this car
for 21 years. It’s a 1989 560SEC. When I got it the mileage was 37,400. It now has about 79,000. It looks like new inside and out and drives very well. I notice the fuel smell occasionally while driving it, but when I put it away in the garage, the smell is extremely strong. All I’ve done is to look under the hood for anything obvious. I’ve also check the gas cap and when I remove it, there is some suction. I plan on putting it up on a lift to see if there are any fuel lines leaking. There is no pool of fuel ever, even immediately after driving it.
Es esta una buena pregunta?
Puntuación 0
4 comentarios
what have you checked? When can you smell the fumes? Where is the smell coming from that you can discern?
- de
@marhil if you have a lift to use... I'm jealous. But yeah check the fuel lines all the way to the motor. Not exactly familiar with these motors, but if it has an air cleaner on top of a TBI or carb setup, take that off as well, and try running the motor. Use a flashlight to look in the engine compartment and see if you can see anything. That engine bay looks very cramped (compared to my 1994 chevy suburban... so much room.in the engine bay!!) Check your plugs also, make sure they're good. If they're going bad, or the wires are, you may not be burning all the fuel, so you'll get a gas smell from the exhaust
- de
@marhil also, you only have 79k on it? Wow... for that age thats actually quite impressive. My 1994 suburban has 267k on it. Haven't owned it for long though...
- de
I have the same exact problem with my 1989 Mercedes 560SL & looking for a solution! Did you ever resolve the problem, Gordon?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
The fuel tank may have a fuel vapor hose that runs to the front of the car to a charcoal cannister. if the vent hose is loose, you won’t get a fuel drip, but will smell fumes. This is covered by an emissions warranty for a long time. Take it back to the dealer.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
I have the same problem with my 1989 Mercedes 560SL & looking for a solution. Emissions warranty on a 32 year old vehicle!? Did you ever resolve the problem, Gordon?
- de
Electro hydraulic actuator valve by Bosch. It’s a small plastic and copper valve on the side of the fuel injector distributor. It was leaking just enough fuel to make the smell. Replaced it and smell was gone.
- de
Añadir tu respuesta
Gordon Opp estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 35
Todo El Tiempo: 1,600
