Surface Book 1/2 13.5" Adhesive Strips this for screen replacement?
Surface Book 1/2 13.5" Adhesive Strips - iFixit for screen replacement or battery replacement ?
Es esta una buena pregunta?
From the description, says digitizer screen to frame. As for batteries, I typically use double sided tesa tape. I’ve done surface pros using tesa tape and it works out just fine btw.
This adhesive film secures the front glass digitizer screen to the frame of your Microsoft Surface Pro 1/2 13.5".
Complete your replacement of the front glass with new adhesive. There is no measuring, cutting, trimming, or shaping needed with these custom cut adhesive strips.
Fue útil esta respuesta?
The battery adhesive is so strong that even if you pull the battery off, you can reuse them as long as you don’t tear or wrinkle them.
Thanks, it`s very helpful.
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 293
