Saltar al contenido principal
The Apple Extended Keyboard is a USB-A extended keyboard with an aluminum body and a numeric keypad.
Preguntas 5 Ver todo
Mac keyboard typing wrong letters
hi there!
I’ve got issue with my extended mac keyboard. As an exemple when i’m punching the letter P, the O also appear.
It also doing it with the L and the ;
I noticed that these keys are alongside on the keyboard.
Someone have a solution with this issue?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
You must have had a spill into the keyboard so the signal lines are damaged shorting out.
Think of it this way… Your keyboard is a grid of horizontal and vertical lines. The point where they cross is the Key shorting them to make the given signal to the keyboard encoder. This is all done within the keyboard.
Sadly, Apple does not design its newer keyboards as serviceable. Time for a new keyboard ;-{
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Thanks a lot for your answer Dan! :-)
- de
Respuesta Más Útil
Replacement required
Puntuación 1
Añadir tu respuesta
Jean-François Duguay estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 51
Todo El Tiempo: 2,634
