Saltar al contenido principal
Adaptador de corriente alterna magnético de segunda generación para productos MacBook, lanzado por primera vez en 2012. No es compatible con sistemas de generaciones anteriores Disponible en versiones de 45W, 60W y 85W.
Preguntas 23 Ver todo
Magsafe 2 85W charger will not charge 2015 MacBook Pro
I have an old 85W Magsafe 1 charger with a T-tip (yes, it’s an odd ball one) that I converted to a Magsafe 2 T-tip by resoldering a brand new Magsafe 2 T-tip cable. It charges all all of my laptops without issues:
  • 2013 13” MBP Pro
  • 2014 15.5” MBP Pro
  • 2015 13” MBP Air
They all show light up solid green when charged up or solid amber when charging.
Unfortunately, the charger won’t power up my 2015 13” MBP which has the battery disconnected. The amber light on the cable blinks and then turns off. My other magsafe 2 chargers will at least power it up with a solid amber light. As a test, I tried at least three different chargers and they were able to power it up without issue.
I highly doubt I botched my conversion. Are there other differences either in the MBP 2015 Pro circuitry or the Magsafe 1 circuitry that may cause it not to charge.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Ah, you really can’t use it as the power is lower. To add to it the MagSafe connector has a ID within it to ID the charger and the voltage to the system to prevent improper usage.
Teardown and exploration of Apple's Magsafe connector
Time to get the correct charger for your system. And please for your safety and your systems use a real Apple charger! The chargers you find on Amazon and eBay are knockoffs which will damage your system and have been known to set buildings ablaze!
Fue útil esta respuesta?
Puntuación 1
I keep a couple of these Apple MagSafe to MagSafe 2 Converters around. They are cheap and work very well.
https://www.googleadservices.com/pagead/...
Puntuación 0
Añadir tu respuesta
AppleGuyPie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 379
