Saltar al contenido principal
Revisión de mediados de 2013 de la línea de consolas Xbox 360, con 4 puertos USB y conectividad Wifi interna.
All lights on my xbox 360 turn red including the center light
All lights on my xbox 360 turn red including the center light but it dose not blink it just turns solid red
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
When you have the console hooked up to a TV, do you get a screen with an error message on it or no? The error should read as “Exx” where the x’s are numbers. Also, what color is the light on the power brick?
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
no i dont have a screen error but the power brick turns red to
- de
If the light on the power brick is red, that indicates a failure with the power brick. See if you can get your hands on a replacement for further testing.
- de
its not working at all now
- de
@mohemmed ahmed Are you using a different power brick or no? If not and you have no lights on the power brick or the power brick is still red then that brick may have given up completely.
Also, make sure all your connections on your power brick are secure, I know the original models could get a bit picky if everything wasn't perfectly connected.
- de
https://m.youtube.com/watch?v=LDM7SXwgb6...
Puntuación 0
Añadir tu respuesta
mohemmed ahmed estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 139
