Una actualización menor de la MacBook Air de finales de 2018, con el mismo número de modelo (A1932) y número EMC (3184). Este modelo presenta una pantalla True Tone y una batería ligeramente revisada.
Desplázate por este tema para encontrar el lugar apropiado para este comentario. Luego haz clic en "Añadir comentario a esta publicación" para moverlo.
2 comentarios:
Most likely your system is in CPU safe mode. This is when the systems SMC sees a defect and reduces the CPUs clocking and ramps up the fan.
Lets see if you can discover an error running the onboard diagnostics. Restart your system and press the D key did you get any error codes & messages?
Do you have many programs running in the backupground?
Or you may check whether the system and hardware are needing upgraded. And the hard drive space, (this is important), make sure there is enough free disk space.
Mac startup key combinations
- de Dan
related tutorial: https://www.minitool.com/news/how-to-spe...
- de Cassie Wu
