Saltar al contenido principal
Aquí puedes consultar guías de reparación para MacBook.
Preguntas 3786 Ver todo
The coin lock cap broke off and stripped
The coin operated battery lock cap broke off on my MacBook and the lock itself is stripped.what should i do? The battery doesnt lock now so i have to tape it to the case..plz help
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
Can you post a picture of how exactly it's broken?
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
If the switch is stripped and can't be operated with a coin anymore, you can try using superglue (to attach a coin or something else to grab onto) and get enough leverage to twist it back into the locked position.
Fue útil esta respuesta?
Puntuación 3
The battery lock mechanism is part of the MacBook bottom case and it can't be swapped. You need to replace the bottom case. Try to find a used bottom case in good condition.
http://www.blogcdn.com/www.joystiq.com/m...
Puntuación 0
Hi
I've got a similar problem except the lock pinged off whilst in the locked position so I can't actually take the battery out!! To add insult to injury, this only happened when I was about to replace the battery which no longer charges!
Is there a way of removing the bottom case without taking the battery out?
Puntuación 0
Añadir tu respuesta
sanane estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 5,139
