Replacing ethernet port on Acer Nitro AN515-53
The cable going into the Ethernet port on my Acer Nitro AN515-53 V1.22 was bumped several times as the cable stuck out from the laptop body. It now has in inconsistent connections, even when using new and trusted cables. The door latch holds the connector though the cable plug may be loose.
If I fiddle with pressures and use a rubber band around the laptop just right it connects until the cable moves too much. I’m now using a 90degree cable to reduce further strikes, but that’s a bit like closing the barn door after the horses escaped.
The “right fix” seems to be replacing the failing port, but as a non-professional handyman with some electronic surgery experience I would like to watch a video or write up but have yet to find either.
Seeking guidance from those with more experience here before I solo.
Es esta una buena pregunta?
