Saltar al contenido principal
The Fitbit Alta HR is a fitness tracker wristband released in March 2017. The Alta HR is similar to the Alta, which was released in February 2016.
Is it possible to replace the charging port?
The charging contacts are getting very damaged and causing inaccurate charging. Is there a way to buy this piece and replace it, how do I replace it? Thank you. Fitbit Alta HR
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
if you can access the port and the board it should be possible to replace the charging port.
if you dont have the proper tools, IE hot air station, solder, flux, new port it could be more costly to do it yourself as opposed to sending it to a repair shop.
hope this helps!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Nicole estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 368
