Saltar al contenido principal
La revisión de 2016 de Apple a su línea de computadoras portátiles dirigida a usuarios profesionales. Cuenta con una pantalla Retina de 15 pulgadas, 2880 por 1800, Intel Core i7 de cuatro núcleos, opciones de almacenamiento de 256 GB / 512 GB / 1 TB / 2TB, 16 GB de RAM y un teclado equipado con una barra táctil. Lanzado en noviembre de 2016. Características del modelo A1707.
Preguntas 20 Ver todo
How to change keyboard of MBP 2016 on my own
I need to change the keyboard. Is there any way to do it myself? I have not found the exact keyboard in any online store so far. I guess there is a reason why there are no manuals/tutorials for this procedure on this website?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Yes, there is a reason. Most people will get Apple to do the replacement for free, using this program
https://support.apple.com/keyboard-servi...
UPDATE
Here’s a video on how to do it:
https://www.youtube.com/watch?v=6UqR9jHm...
Fue útil esta respuesta?
Puntuación 3
5 comentarios:
Thank you for the fast reply! The problem is I can't cause I spilled juice over it way back in 2017 and they will not replace it in this case. The only chance I had from their side was to replace the whole bottom part and this was unnecessary expensive so I decided not to do it.
- de
Ouch! Then you'll need to replace the full uppercase assembly!
15" MacBook Pro, Top Case & KB US - Space Grey, Apple P/N 661-07954
15" MacBook Pro, Top Case & KB US - Silver, Apple P/N 661-07955
That will set you back $200 USD and you'll need a battery as well. and hopefully your touchpad is working otherwise you'll also need it too!
- de
Hey, that sound good! 200$ is definitely worth it, the Computer itself runs as if it is new. And the Touchpad works perfectly too. So thanks for the links I'll try it.
Can I reuse the Battery that is already in the Mac Book?
- de
Okay thanks for the tipps! It was really helpful
- de
Añadir tu respuesta
Josef Tulpenhauer estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 304
