Saltar al contenido principal
Portátil Dell Inspiron 1420 de 14.1", lanzado en junio de 2008. Identificado como el 1420 en el marco sobre el teclado, disponible en 8 colores diferentes.
Preguntas 20 Ver todo
Can I use an 14.1" 30 pin panel?
The LCD panel on my Dell Inspiron 1420 is slightly busted and I want to buy a new one, but I’m uncertain how to look for a compatible panel. Can I use and 14.1” panel with a 30 pin interface or must I use ONLY one’s listed as explicitly compatible with this laptop?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Generally, it is best to buy a panel listed as compatible with your laptop because factors such as panel thickness, width and height, and required voltages can vary. However, if you are certain all factors (dimensions, voltages, etc) for the panel in question are compatible with your laptop, it should be fine. Here is an iFixit guide for replacing your screen when you find a compatible panel:
Dell Inspiron 1420 Display Replacement
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Ok, so just carefully research and check that all the specs line up and it'll be fine. Good to know for the future, thank you!
- de
Añadir tu respuesta
Lorelei Rareheart estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 52
