Saltar al contenido principal
Tablet PC de alto rendimiento de tercera generación lanzada por Apple en octubre de 2018. Modelos A1876, A2014 y A1895.
Preguntas 20 Ver todo
My iPad pro 2018 12.9" lost backlight
Hi all, this is my first post. My iPad pro 2018 12.9 inch (model 1895) went black during usage outside at 28°C. Then I noticed that the actual display shows picture but the backlight is not illuminating any more. I have opened the iPad and checked the logic board for visual damage but everything seems to be OK. The filters next to the display connectors are also ok. Does someone has experienced this issue or has the schematic for my ipad? Would be very helpful
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
4 comentarios:
How did you test the filters
- de
I have used this video as a guide: https://youtu.be/6FnO1oY-voM
It is not the same model but has a similarly design at some circuits.
I did not had any burned filters but found a burned cap (optical burned but not shorted).
- de
Do you have a multimeter
- de
Yes. Do you have schematics available for this model which is showing where the backlight circuit is located?
- de
Agregar un comentario
1 Respuesta
The backlight on the screen might of failed or the backlight circuit failed on the logic board.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Serdar Yagcioglu estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 25
Todo El Tiempo: 1,304
