charging the devise the internal battery "inflated" to triple it's siz
charging the devise over night, the internal battery “inflated” about 3-4 times of it’s size and capacity and “buckled” the glass display and the back cover and the glue separated. I removed the back cover completely. Is there possible to replace the battery with a new one (normal size), lucky it didn’t explode.
Es esta una buena pregunta?
3 comentarios
I thought that I can get an answer how to fix the problem, I guess my expectations from your site were inflated like my battery!
I have a suggestion for those who want to answer:
If you have nothing to offer, better just SHUT UP!
- de david almogi
Hi @grumpybearr ,
What answer were you expecting?
The battery has become swollen. You cannot repair a swollen battery. Replacing it is the first step.
The Most Helpful answer below has information on how to do this and how to source a replacement battery
As to how it got this way is another matter. Usually it is a problem with the battery itself and not something else in the device that caused it to happen
Moderator
- de jayeff
@grumpybearr I am sorry we did not meet your expectation. Anyhow, the reason why your battery swelled up is because it got overcharged. This usually happens when the voltage is incorrectly detected by the charging control system which is part of your battery. Those batteries swell up because the overcharge reactions between the electrodes and electrolyte, creates heat and gases. The wrap prevents those gases from diffusing out and the pouch which contains the battery subsequently swells up.
Changing the battery will correct this since the overcharge circuitry is in the battery.
- de oldturkey03
